Hallo Leute,
habe heute beim Stöbern einen interessanten Artikel gefunden:
88 MAF to MAP
By sappyse107
GM released memcal updates to remove the faulty MAF sensors (they are known to crap out) and allow a simple MAP setup. Since the MAP sensor is already installed, this is a simple install. First, you need to get the Chip upgrade that converts your vehicle to MAP only. The GM dealer should be able to help you here, or if you can burn your own, the files are located under chip tuning.
Put the new memcal into the computer, remove the MAF sensor, and wire in an Intake Air Temperature (IAT) sensor. You can find a newer air box off a newer model, or just cut a hole in your intake path for the sensor. The wires to the IAT are the same color as the MAF wires (The MAF had the IAT built into it).
© 2001-03 60DegreeV6.com
Hat einer von Euch vieleicht damit schon Erfahrung oder weis was genaueres darüber ???
Gruß Bernd
Umbau MAF nach MAP ???
v6power
- Ride: Firebid 89 173cui
Keep on cruisin
Keep on cruisin
